Hi all,
I ordered the i4 and I am wondering if it is available with car as a standard, as I do not find it in configurator?
However, is only Schuko adapter with it or also 16A CEE?
Thanks for help
Hi all,
Thanks for help
Hello,
BMW removed the flexible charger as a free addition to all i4 orders, you need to order it separately now..
But when you order, do you get 16A Cee adapter in the package too, or is sold separately?
No. Only Schuko is included.
You will need to order the CEE Adapter seperately.
There are 2 Versions!! Doesn´t fit to each other.
Flexible Charger 1.0
BMW Adapterkabel CEE 16 A (blau, 1-phasig) 61905A138D4
https://www.bmw.de/de/shop/ls/dp/physical-goods/728174
Flexible Fast Charger 2.0 (Rückseite des Flex Charger 2.0 ist in den meisten Fällen die Teilenr. 8490509-04 oder 8490509-05)
BMW Adapterkabel CEE 16 A (blau, 1-phasig) 61448490522
https://www.bmw.de/de/shop/ls/dp/physical-goods/901609
BMW Adapterkabel CEE ROT 16A) 61448490523
https://www.bmw.de/de/shop/ls/dp/physical-goods/901618
Der Flexible Fast Charger 1.0 und seine Adapter sind nicht kompatibel mit dem Flexible Fast Charger 2.0 und umgekehrt.
Great. So now I have FIN nr for some time and will get the car next Monday. In decoder I see charger is really not included (error in car configurator)
Do you suggest just to simply buy BMW Flex Charger with CEE adaptor, or is there anything better on ebay.de or amazon.de this times? It needs to be flexible, no wallbox. Any settings not needed as can be set in car.
I would simply have a look at kleinanzeigen.de - you can get a whole charger including the CEE plug for around 200,- Euro.
It doesn´t have to be a BMW charger. Any other brand will do it. Electricity is electricity...
https://www.kleinanzeigen.de/s-cee-ladeger%C3%A4t/k0
Good thing about the flexible fast charger is that you can put different plugs on. Only CEE16 does not help much, or can you guarantee that it will also work when only one phase is available?
You can also get an original BMW Flexible fast charger for that price. I bought mine for 175 EURincl. p&p. (Normal price is hefty 370 EUR). I ordered the CEE cable from BMW Baum for less than 100 EUR. I bought Version 2.
I ordered mine on eBay.
Arrived the last days at home, but I have to check if it’s 2.0 or 1.0.
However, 1.0 and 2.0 are the same, except the connector for the interchangeable outlet cable.
I will check if I received the 1.0 or 2.0 and will than order the compatible CEE connector cable.
